jc_cornwell
May 24, 2020Initiate
Nighthawk Mesh 6 wifi dropping macbooks only, can't reconnect - windows not a problem
Hi just got the nighthawk mr60 wifi mesh with a router and two satellites. My windows machine never has a problem. My 2 mac laptops are often dropped, then when I do reconnect to the modem, it says...
Poynter-2
May 27, 2020Guide
I have the same issue with my Macbook Pro. I got this Mesh system two days ago. And two days in a row the issue has occurred where the router assigns an IP for my MacBook, but the next day the IP will not function. The exclamation point on MacBook wifi icon appears. The only solution is to reboot the router to get a functional IP. Let's see if it happens tomorrow.
araghava
May 27, 2020Star
I have filed a support ticket for this issue. It would be good if the others who are seeing this issue also do so.
- Poynter-2May 27, 2020GuideWill do
- Poynter-2May 27, 2020GuideI have also filed a support ticket for the issues in this thread.
- Poynter-2May 27, 2020GuideHere’s the response I got from support to this issue.
“In order to isolate the issue, please refer this link and reserve ip for these devices-https://kb.netgear.com/25722/How-do-I-reserve-an-IP-address-on-my-NETGEAR-router
Please let us know the results, so that we can determine the next action.”- araghavaMay 27, 2020Star
I have disconnected the router for now because it was too disruptive for my daughter given she is online on zoom all day for her classes. If you can try what support suggests that would be great.
