jc_cornwell
May 25, 2020Initiate
Nighthawk Mesh 6 wifi dropping macbooks only, can't reconnect - windows not a problem
Hi just got the nighthawk mr60 wifi mesh with a router and two satellites. My windows machine never has a problem. My 2 mac laptops are often dropped, then when I do reconnect to the modem, it says...
Poynter-2
Jun 06, 2020Guide
Here's what tech support advised me to do to troubleshoot the bugs. Re-flash the firmware and downgrade to the previous version 1.0.3.86 for both the router and satellites. (Be sure to turn off automatic firmware updates.) Disable the AX setting in the wireless section. Change channel of the Wireless Network (2.4GHz b/g/n) to number 11. Change channel in Wireless Network (5GHz a/n/ac) to number 161.
I am testing this and finding fewer connectivity issues. I suspect that it will be advised to change things back in reverse order after monitoring and testing in between each step for a few hours.
Poynter-2
Jul 08, 2020Guide
After going back and forth with support, I am returning this system to Costco. Support told me there is no bug in the firmware. They even said 1 router and 2 satellites might be too much for my home and maybe there was interference. So I removed the satellites. But then there were dead spots. So it seems CNET.com's review is correct. I shouldn't have ignored them. This model is an unreliable mesh system. I was hoping for the price, it would be usable. But this is not the case. I am still getting the exclamation marks on the wifi icon on my macbook pro and ipads sometimes. Also the connection drops periodically when moving about the house. The chromebook was not allowed to connect many times, and we had to restart the router to get a connection. So I have purchased and successfully testing the Eero's 3-pack mesh system. It works like a dream for the same price as Nighthawk Mesh 6 wifi at Costco. The Eero system always routes my devices to the best connection, and there have been zero dropped connections or connectivity issues. Great coverage in the house, garage, and yard. And the Eero user app is quick and robust. Netgear's is slow and glitchy.
- araghavaJul 09, 2020Star
Same here. I'm going to return the unit to Costco. I'm debating between the TP-LINK X60 DECO and Google Nest Wifi. Now I'll consider the Eero as well. Thanks.
- bantaiiJul 09, 2020AspirantThere's a new FW update today. I'll report how it goes.
The release notes says "Fixes security issues."
Very helpful.
