jc_cornwell
May 24, 2020Initiate
Nighthawk Mesh 6 wifi dropping macbooks only, can't reconnect - windows not a problem
Hi just got the nighthawk mr60 wifi mesh with a router and two satellites. My windows machine never has a problem. My 2 mac laptops are often dropped, then when I do reconnect to the modem, it says...
jc_cornwell
Just to add a little more detail... I was on my windows machine next to the missus using her mac. All of a sudden she was dropped, I was not. I "forgot" the network on her mac and reconnected with fresh password request. It connects to modem, but then gives the "can't connect to internet error". Haven't been able to connect since. ALSO - exact same thing happens on another macbook my daughter uses - sometimes magically connects, sometimes will never connect, with same IP address error.
hocalbee
Aug 01, 2020Aspirant
Same issue here! My iPad 2019 drops wifi connectivity when moving from satellite to router or vice versa. It only resumes after disable/enable wifi in iPad. Other devices also experience this randomly including ThinkPad T490s, iPhone XR
