jc_cornwell
May 24, 2020Initiate
Nighthawk Mesh 6 wifi dropping macbooks only, can't reconnect - windows not a problem
Hi just got the nighthawk mr60 wifi mesh with a router and two satellites. My windows machine never has a problem. My 2 mac laptops are often dropped, then when I do reconnect to the modem, it says...
jaycamcat
Aug 14, 2020Aspirant
I have the same exact issue. I can't believe this.
I've been countless hours on hold and talking to tech support multiple times.
They've tried everything: changing wireless channels, updating firmware, disabling wifi 6 (ax), nothing has worked.
This happens on my macbook, iphone, ipad. All these devices work just fine with all the other hundreds of wifi connections I've used.
btreu
Aug 14, 2020Initiate
So this sort of issue seems to exist across all netgear models, and it seems to be something that happens in combination with the way netgear products interact with the Mac OS and iOS, and what gets stored in PRAM and NVRAM.
Resetting both these in my devices helped/solved the issue and significantly improved network performance.
Discussions with Apple about what might be going on were responsive.
- jaycamcatAug 16, 2020Aspirant
btreu thanks for that suggestion. I haven't heard of that one. I'm trying it out now.
- jaycamcatSep 03, 2020Aspirant
btreu it looks like resetting NVRAM and PRAM helped and made a very noticeable difference. But it wasn't perfect, I'd still notice it drop a few times in a week. But that's still better than dropping once every few minutes!
I found a solution that seems to work even better than that.
I used the manufacturer warranty to get an exchange. That said, I wasted countless hours dealing with technical support.
In hindsight, the most ideal situation: buy it from a retailer / reseller with a generous return policy (NOT BEST BUY). Within that return window, make sure you open it up and confirm that it works. If it doesn't work, return it immediately to the retailer and get something else.
RMA horror story:
I ended up shipping back the router and satellite, and they literally shipped me back a router, but NO satellite. I had to call (let's say I made it clear was very VERY UNHAPPY about it), and they blamed it on their warehouse team (whatever, I don't care! Not my problem, just fix it!) Even worse, they asked me what was the serial number of the satellite I returned to them? WELL--I didn't know I had to record the serial number of the satellite. I had the shipping tracking # so I know it arrived. Lesson learned: save all your serial numbers.
You will waste a ton of time with customer service because they're always asking you for your case number (serial numbers, name, email, phone, all the information that they basically already have!), closing and opening new case numbers (even though it's a same case--which I suspect is to make their customer service metrics look better, as if they're actually solving more problems). You'll be on hold as they pass you from department to department. They'll give you a case number, and then ask you back to repeat the same case number, a few minutes later. Why?
As their customer service is in India, your phone call will also like drop a few times likely because of their bad VoIP implementation (irony for a networking company?)
- Kuffdam303Dec 14, 2020Aspirant
Hey
So I got this router last week - all devices in my home are solid on the network except my new Apple Macbook Pro 13" M1 laptop. It drops constantly - I will be on video calls and it just hangs or drops off the network then asks me to share my password from my iphone.
I have an IMAC and no issues, Iphone no issues - just this new Macbook Pro.
I'm going to send the Netgear router back and re-install the Linksys Velop which I was replacing... Pretty bummed as the speeds were great but I need this laptop as my work machine. Why hasn't Netgear fixed this - poor show...
