jc_cornwell
May 24, 2020Initiate
Nighthawk Mesh 6 wifi dropping macbooks only, can't reconnect - windows not a problem
Hi just got the nighthawk mr60 wifi mesh with a router and two satellites. My windows machine never has a problem. My 2 mac laptops are often dropped, then when I do reconnect to the modem, it says...
pbredenberg
Feb 01, 2021Aspirant
I'm having the same issue using 5GHz network with my MacBook Air 2020 M1. During video calls when connected to 5GHz, internet connection locks up constantly. I'm going to try a firmware update as I see one is available for my model.
