jc_cornwell
May 24, 2020Initiate
Nighthawk Mesh 6 wifi dropping macbooks only, can't reconnect - windows not a problem
Hi just got the nighthawk mr60 wifi mesh with a router and two satellites. My windows machine never has a problem. My 2 mac laptops are often dropped, then when I do reconnect to the modem, it says...
skander
Feb 03, 2021Aspirant
Just adding one more to the queue with the same issues as all the others. Bought a RAX45 Nighthawk last week after our ISP provided router crapped out. I have a work PC and the router works fast and reliably. My spouse has a Mac for work- the router drops zoom calls regularly and is near unusable. Very disappointed and planning to return the product. Extremely frustrating
- diogormendesJul 15, 2022Follower
Having the same issue here. How annoying !! If I read this before buying đ
