jc_cornwell
May 24, 2020Initiate
Nighthawk Mesh 6 wifi dropping macbooks only, can't reconnect - windows not a problem
Hi just got the nighthawk mr60 wifi mesh with a router and two satellites. My windows machine never has a problem. My 2 mac laptops are often dropped, then when I do reconnect to the modem, it says...
skander
Feb 03, 2021Aspirant
Just adding one more to the queue with the same issues as all the others. Bought a RAX45 Nighthawk last week after our ISP provided router crapped out. I have a work PC and the router works fast and reliably. My spouse has a Mac for work- the router drops zoom calls regularly and is near unusable. Very disappointed and planning to return the product. Extremely frustrating
diogormendes
Jul 15, 2022Follower
Having the same issue here. How annoying !! If I read this before buying đ
