Jasm61
May 01, 2021Initiate
Nighthawk Mesh 6 WiFi Router vulnerabiity software update needed
I just bought the Nighthawk Mesh WiFi 6 system AX1800 MK63. The app is telling me that the router is vulnerable and at high risk from cyber threats. They recommend I check for the latest manufacture...
- May 04, 2021
Hello Jasm61,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
Christian_R
May 04, 2021NETGEAR Employee Retired
Hello Jasm61,
Christian
- Jasm61May 08, 2021InitiateThanks Christian! I was looking for a number to contact them but couldn't find it; your link to open a case was really helpful. It turns out that it was the Armor that was causing the vulnerability issue plus it started blocking some websites that I knew were good. I removed the Armor and the issues stopped. I was also told that Armor isn't necessary to keep the router or my internet safer; it's just an anti virus add-on like many others - that costs extra money after 30 days.
Again, thanks for your help :)
