bigfish
Aug 17, 2020Aspirant
nighthawk mesh app network map
Hi. Am installing a mesh router with two satellites. One is having trouble staying connected, and so while trying this and that, I have gotten it so that both satellites are called Satellite-1. Both ...
- Aug 22, 2020
Hi bigfish,
To change the names of the Satellites
1) Open Nighthawk app / click network map / click on the satellite you want to name change / click details / edit Satellite name
Kev
Christian_R
Aug 21, 2020NETGEAR Employee Retired
Hi bigfish,
If you recently purchased the device, I would recommend contacting our support team to assist with getting your device installed. You may contact support by using the link below.
https://www.netgear.com/support/default.aspx
Christian
bigfish
Aug 22, 2020Aspirant
Thanks. I did eventually get it straightened out.
