teejay58
May 28, 2024Aspirant
Nighthawk Mesh blocking device IPs?
I have a setup that looks like this: T-Mobile -->Firewalla firewall --> Nighthawk Mesh -->IoT, ipad, phone, etc. I used to be able to get a notification on my firewall when someone was gaming...
teejay58
May 29, 2024Aspirant
On the bottom of the router it says it's a Nighthawk Mesh WiFi 6 Router MR60. Didn't have time to troubleshoot last night, but looks like I'm going to need to factory reset again. I couldn't logon to the router or the mesh system, even though I had all blue lights on the router and satellite. 😞
May 29, 2024Guru - Experienced User
FR and then setup from scratch using a wired PC as seen here.
Then configure the MK system for AP mode as seen here.
- teejay58Jun 03, 2024Aspirant
The reason I had trouble finding the AP switch is because it was really dim and grayed out. But I found it and now all is mostly fine. Thank you.
- FURRYe38Jun 03, 2024Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
