mrob
Feb 11, 2020Guide
Nighthawk Mesh MK62 Dropping Internet Connection
I recently replaced my old router with this setup and the internet connection keeps dropping. Getting a wifi error "No Internet Connection." The wifi signal is strong but the internet connection rand...
Cletus
Mar 06, 2020Guide
Well it been about a week now with no issues. The laptop is now getting a fixed ip address based on the mac address. The symtoms have dissappeared so I consider this workaround an acceptable solution.
teaston
Mar 18, 2020Aspirant
My wife and I are having the same issue with our Windows 10 computers. How do you reserve an IP address based off of MAC address?
Thanks
- Christian_RMar 19, 2020NETGEAR Employee Retired
Hello teaston,
May you try disabling AX to see if there are any improvements.
Christian
- teastonApr 02, 2020Aspirant
Hi Christian_R
How do I disable AX? I followed previous instructions found online, but I do not see the Check Box when I login to routerlogin.net
Thanks,
Tim
