mrob
Feb 11, 2020Guide
Nighthawk Mesh MK62 Dropping Internet Connection
I recently replaced my old router with this setup and the internet connection keeps dropping. Getting a wifi error "No Internet Connection." The wifi signal is strong but the internet connection rand...
PaulieP
Apr 13, 2020Aspirant
Had the same problem, power cycle your satellite. If that doesn't help 5ry to change your channels for your network using the url portal to input the channel and using the Nighthawk app to easily identify the best channels for your device. Also it can help to use a static IP for increased stability on the network, if you go this route you may want to use a secure VPN to supplement the security lost for going static.
Cheers,
PaulieP
Cheers,
PaulieP
