mrob
Feb 11, 2020Guide
Nighthawk Mesh MK62 Dropping Internet Connection
I recently replaced my old router with this setup and the internet connection keeps dropping. Getting a wifi error "No Internet Connection." The wifi signal is strong but the internet connection rand...
TigerPrince
May 11, 2020Initiate
Same issue as described by other individuals. Dropping connection, believe it is the 5 ghz connection. Fast but unreliable/unstable. I do not have anything unusual like foil in my insulation or 4 ft concrete walls. Just simple walls that previous routers did not seem to have an issue with. Very dissapointed. Figured that Netgear would be on top of it.
All I want is a stable, reliable, fast connection!
Called support 3-4 times. Tried changing settings, channels, etc..., nothing different, still dropping connections.
When will this issue be fixed??? Why is this taking so long to get this taken care off???
If 5 people are saying that they are having the same issue, something is not right.
wifiisnotfast
downgraded to this from a google wifi mesh system. i am having the same issue as everyone else on this thread. I have the mk63 which is the 3 pack and after every few hours i have to reset one of the satellites. I do not want to disable AX, as it is the reason why i bought the device. Also i am over the return policy and now have a paper weight device that i paid alot of money for with no support from vendor.
- araghavaMay 12, 2020Star
I reset my MK63 couple of days back and installed the latest firmware. I was told by support that this was released around May 6th or 7rh. After this for the last 3 days the system has been stable. No issues with connectivity both wireless and wired. Fingers crossed.
