mrob
Feb 11, 2020Guide
Nighthawk Mesh MK62 Dropping Internet Connection
I recently replaced my old router with this setup and the internet connection keeps dropping. Getting a wifi error "No Internet Connection." The wifi signal is strong but the internet connection rand...
Christian_R
Jul 10, 2020NETGEAR Employee Retired
Retired_Member - Send me a private message with your email, contact info, and serial number and I can have our support team reach out.
Christian
Retired_Member
Jul 10, 2020Hi Christian_R
I will send you a PM.
But would it not make sense to as well address this so that people would not things are taken care on?
Thanks
Dennis
- FormozoJul 20, 2020Tutor
Hi Dennis,
Any news from your side? Any solution from Netgear? I have here a paper weight device waiting for any kind of solution. I had to buy a cheaper TP-Link Deco Mesh, that is working fine (and 100% stable) since then. But I'm still waiting for a solution.
Luciano
- Retired_MemberJul 20, 2020
No clear solution so far.
Router and satellite were reset and debug mode is turned on to track down the system -- as I had some issues (next morning the internet was gone - red light) and I had to reboot I still need to send some additional information out.
The weekend gave me a stable system - if it is really another round of firmware upload and reset I would be very surprised but we'll see if the first debug report will help.
Best.
D
- CletusJul 20, 2020Guide
I just received my new replacement that failed. Had the red light on the front. Per Netgear they finally sent me a new one after 6 weeks. In the mean time I resurrected my old Linksys EA4500 with an OpenWRT firmware install. Quite easy. In the meantime I purchased another Linksys EA4500 for $11 on ebay and installed OpenWRT on it and it has been working fine as my sateliite.
No thanks for Netgear but this cheap solution with these old Linksys EA4500 and OpenWRT are working quite well. No wifi 6, but I don't have any wifi 6 devices yet.
Just another solution for y'all to think about.
