mrob
Feb 11, 2020Guide
Nighthawk Mesh MK62 Dropping Internet Connection
I recently replaced my old router with this setup and the internet connection keeps dropping. Getting a wifi error "No Internet Connection." The wifi signal is strong but the internet connection rand...
mjcalabrese
Aug 05, 2020Apprentice
SMontesdeOcaI do not see a 1.0.5.102 version of firmware for the MK62 on the <https://www.netgear.com/support/download/> site. I thought to myself, "No, I checked before I boxed it all up yesterday".
I just found the firmware by entering the MS60 product. There are links to both the MR60 and MS60 in here: https://kb.netgear.com/000062170/MR60-MS60-Firmware-Version-1-0-5-102
MR60: http://www.downloads.netgear.com/files/GDC/MK62/MR60-V1.0.5.102_2.0.44.zip
MS60: http://www.downloads.netgear.com/files/GDC/MK62/MS60-V1.0.5.102_2.0.44.zip
SMontesdeOca
Aug 05, 2020Aspirant
Hi mjcalabrese, yep, while not directly associated as the latest upgrade, it is shown some lines below what appears to be the current vesion (98).
Have you, or anyone tried it? I'm just about to give it a try ... before 98 it was all smiles and all ok with my mesh system. As soon as i upgraded to 98, boom, daily disconnections and as some posted earlier ... I'm starting to be a "persona non grata" around the house! :D.
Will wait a bit and see/read if anyone else tried it, and give it a try.
Thanks,
- mjcalabreseAug 10, 2020Apprentice, ,
Are there any updates on this topic? I’m wondering if everything is now working with the latest firmware update?
I have the same experience as HackedReactor: 1 week of family-friendly WiFI. I actually used the Google WiFi app to show my son he was connected to the satellite because his door was closed and it forced his connection to the other side of the house.- ak3tAug 13, 2020AspirantDoes the attached pic answer your question? Not only is it a screenshot of rebooting my MR-60, but the app now says orbi. App also thinks .98 is latest firmware. It is past time to box it up...
- mjcalabreseAug 14, 2020Apprenticeak3t, there is a newer update now that actually claims to fix the wireless issues.
https://www.netgear.com/support/download/#
https://kb.netgear.com/000062202/MR60-MS60-Firmware-Version-1-0-6-102
1. Fixed WiFi connectivity issue
2. Fixed internet connectivity issue - one WiFi client couldn’t go internet but others are ok at the same time.
https://www.downloads.netgear.com/files/GDC/MK62/MR60-V1.0.6.102_2.0.45.zip
https://www.downloads.netgear.com/files/GDC/MK62/MS60-V1.0.6.102_2.0.45.
Hope this helps.
