mrob
Feb 11, 2020Guide
Nighthawk Mesh MK62 Dropping Internet Connection
I recently replaced my old router with this setup and the internet connection keeps dropping. Getting a wifi error "No Internet Connection." The wifi signal is strong but the internet connection rand...
mjcalabrese
Aug 21, 2020Apprentice
sravs, what specific version of firmware are you on? Just because the MK63 system says you’re on the latest version doesn’t necessarily mean that there isn’t a newer version available.
You should be on this version: https://community.netgear.com/t5/Nighthawk-Mesh-System/Nighthawk-Mesh-MK62-Dropping-Internet-Connection/m-p/1960241#M796
If you are, then please open a new support case and have it escalated to Tier 2 support.
sravs
Aug 21, 2020Aspirant
Thanks for the reply. Yes I’m on v1.0.6.102 Have just checked once again as per attached screenshot. I’ll open a support case.
- mjcalabreseAug 26, 2020Apprentice
sravs, do you have any update on your issues? Was Netgear L2 support helpful?
I did find another similar thread in the Community on the same topic: https://community.netgear.com/t5/Nighthawk-Mesh-System/Nighthawk-MK62-Firmware-v1-0-5-102-Issue/td-p/1956618/jump-to/first-unread-message
