mrob
Feb 11, 2020Guide
Nighthawk Mesh MK62 Dropping Internet Connection
I recently replaced my old router with this setup and the internet connection keeps dropping. Getting a wifi error "No Internet Connection." The wifi signal is strong but the internet connection rand...
sravs
Aug 21, 2020Aspirant
Thanks for the reply. Yes I’m on v1.0.6.102 Have just checked once again as per attached screenshot. I’ll open a support case.
mjcalabrese
Aug 26, 2020Apprentice
sravs, do you have any update on your issues? Was Netgear L2 support helpful?
I did find another similar thread in the Community on the same topic: https://community.netgear.com/t5/Nighthawk-Mesh-System/Nighthawk-MK62-Firmware-v1-0-5-102-Issue/td-p/1956618/jump-to/first-unread-message
