mrob
Feb 11, 2020Guide
Nighthawk Mesh MK62 Dropping Internet Connection
I recently replaced my old router with this setup and the internet connection keeps dropping. Getting a wifi error "No Internet Connection." The wifi signal is strong but the internet connection rand...
Tots2000
Aug 30, 2020Aspirant
It looks like I have fixed mine by reducing my DHCP scope and put my problematic devices on static ip outside of the scope.
I was getting duplicate ip errors in event log even though there were no duplicates. Each time it happened I was experiencing all the issues described in this thread.
I wouldn't have thought such a simple fix would be the solution but you never know!!
jaycamcat
Sep 03, 2020Aspirant
btreu 's suggestion of resetting NVRAM and PRAM helped and made a very noticeable difference. But it wasn't perfect, I'd still notice it drop a few times in a week. But that's still better than dropping once every few minutes!
I found a solution that seems to work even better than that.
I used the manufacturer warranty to get an exchange. That said, I wasted countless hours dealing with technical support.
In hindsight, the most ideal situation: buy it from a retailer / reseller with a generous return policy (NOT BEST BUY). Within that return window, make sure you open it up and confirm that it works. If it doesn't work, return it immediately to the retailer and get something else.
RMA horror story:
I ended up shipping back the router and satellite, and they literally shipped me back a router, but NO satellite. I had to call (let's say I made it clear was very VERY UNHAPPY about it), and they blamed it on their warehouse team (whatever, I don't care! Not my problem, just fix it!) Even worse, they asked me what was the serial number of the satellite I returned to them? WELL--I didn't know I had to record the serial number of the satellite. I had the shipping tracking # so I know it arrived. Lesson learned: save all your serial numbers.
You will waste a ton of time with customer service because they're always asking you for your case number (serial numbers, name, email, phone, all the information that they basically already have!), closing and opening new case numbers (even though it's a same case--which I suspect is to make their customer service metrics look better, as if they're actually solving more problems). You'll be on hold as they pass you from department to department. They'll give you a case number, and then ask you back to repeat the same case number, a few minutes later. Why?
As their customer service is in India, your phone call will also like drop a few times likely because of their bad VoIP implementation (irony for a networking company?)
- AnonymousSep 17, 2020
Feedback.
DHCP is fixed and its running stable.
The ONLY issues now for me. After a while airplay stops working (I cannot connect to the speaker itself). When I reboot the speaker nothing happens. When I reboot the router and satellite everything works again.
I can provide to netgear debug_logs but the current case was closed and I cannot submit it to any case.
Best.
D
