mrob
Feb 11, 2020Guide
Nighthawk Mesh MK62 Dropping Internet Connection
I recently replaced my old router with this setup and the internet connection keeps dropping. Getting a wifi error "No Internet Connection." The wifi signal is strong but the internet connection rand...
GhettoSmurf373
Dec 07, 2020Initiate
I all of a sudden started experiencing connectivity issues as well. I am on the most current version, even tried to back date to version .98. Both router/satellite will connect fine after a modem reboot, stays connected for about an hour, then reboots the entire system. This happened in the middle of the day the first time, so I tried to factory reset on everything and try again (no dice). Called my ISP and spent days ensuring my modem/lines were all fine. Finally broke out a 5-year old Tenda router and everything works just fine.
As luck would have it, this router is 5-months old, so I am out of the 'free' 90-day support window. But I have been doing IT/Computer repair most of my life, something tells me this is still an unresolved firmware issue.
I am going to try disabling AX/advanced features as I just found this forum today, but so far, nothing has worked.
