mrob
Feb 11, 2020Guide
Nighthawk Mesh MK62 Dropping Internet Connection
I recently replaced my old router with this setup and the internet connection keeps dropping. Getting a wifi error "No Internet Connection." The wifi signal is strong but the internet connection rand...
GhettoSmurf373
Dec 07, 2020Initiate
I all of a sudden started experiencing connectivity issues as well. I am on the most current version, even tried to back date to version .98. Both router/satellite will connect fine after a modem reboot, stays connected for about an hour, then reboots the entire system. This happened in the middle of the day the first time, so I tried to factory reset on everything and try again (no dice). Called my ISP and spent days ensuring my modem/lines were all fine. Finally broke out a 5-year old Tenda router and everything works just fine.
As luck would have it, this router is 5-months old, so I am out of the 'free' 90-day support window. But I have been doing IT/Computer repair most of my life, something tells me this is still an unresolved firmware issue.
I am going to try disabling AX/advanced features as I just found this forum today, but so far, nothing has worked.
abhijeetjoshi
Dec 21, 2020Aspirant
Try resetting to factory or disabling traffic meter. Worked for me. Good luck!
- haolecougarDec 21, 2020Aspirant
Thanks Abhijeetjoshi.
Provided this connection is "live" long enough for me to do it
Will try this in the morning, risking too much at this point. Was considering another Netgear product when this happened.
Very disappointed.
The nighthawk app is appalling as well. They should fire whoever created. Looks fancy but really doesn't serve its purpose considering how much trouble it had trying to connect even within their own mesh environment.
I hear that Netgear support is bad but hoping for a X'mas miracle!
Peace
- ak3tDec 21, 2020AspirantHopefully you can get yours working soon as it sucks to have those problems! Knock on wood, my mesh system has been working great since I threatened to return it. LOL. 102 def helped and I also had one satellite on a different version than the other two (it would not update) and once It finally updated, everything clicked and started working well. Good luck!
- haolecougarDec 23, 2020Aspirant
My traffic meter is off all these while.
Just downloaded the logs. Seems like there was a dos attack. Checked the IPs, mostly on port 443
[DoS attack: ACK Scan] from source 151.101.9.176,port 443 Thursday, Dec 24,2020 03:45:13
[DoS attack: ACK Scan] from source 124.155.222.31,port 443 Thursday, Dec 24,2020 03:44:59
[DoS attack: ACK Scan] from source 104.116.20.206,port 443 Thursday, Dec 24,2020 03:44:59
[DoS attack: ACK Scan] from source 124.155.222.31,port 443 Thursday, Dec 24,2020 03:44:52
[DoS attack: ACK Scan] from source 104.116.20.206,port 443 Thursday, Dec 24,2020 03:44:51
[DoS attack: ACK Scan] from source 124.155.222.31,port 443 Thursday, Dec 24,2020 03:44:51
[DoS attack: ACK Scan] from source 104.116.41.227,port 443 Thursday, Dec 24,2020 03:44:48
[DoS attack: ACK Scan] from source 124.155.222.31,port 443 Thursday, Dec 24,2020 03:44:48
[DoS attack: ACK Scan] from source 104.116.20.206,port 443 Thursday, Dec 24,2020 03:44:48
[DoS attack: ACK Scan] from source 104.116.41.227,port 443 Thursday, Dec 24,2020 03:44:47
[DoS attack: ACK Scan] from source 104.116.20.206,port 80 Thursday, Dec 24,2020 03:44:46
[DoS attack: ACK Scan] from source 23.15.99.245,port 443 Thursday, Dec 24,2020 03:44:46
[DoS attack: ACK Scan] from source 124.155.222.31,port 443 Thursday, Dec 24,2020 03:44:46
[DoS attack: ACK Scan] from source 104.116.20.206,port 443 Thursday, Dec 24,2020 03:44:46
[DoS attack: ACK Scan] from source 104.111.207.233,port 80 Thursday, Dec 24,2020 03:44:45
[DoS attack: ACK Scan] from source 104.116.20.206,port 80 Thursday, Dec 24,2020 03:44:45
[DoS attack: ACK Scan] from source 23.15.99.245,port 443 Thursday, Dec 24,2020 03:44:45
[DoS attack: ACK Scan] from source 104.116.20.206,port 443 Thursday, Dec 24,2020 03:44:45
[DoS attack: ACK Scan] from source 124.155.222.31,port 443 Thursday, Dec 24,2020 03:44:45
[DoS attack: ACK Scan] from source 104.116.20.206,port 443 Thursday, Dec 24,2020 03:44:44
[DoS attack: ACK Scan] from source 151.101.9.12,port 443 Thursday, Dec 24,2020 03:42:46
[DoS attack: ACK Scan] from source 69.171.250.34,port 443 Thursday, Dec 24,2020 03:42:45
[DoS attack: ACK Scan] from source 104.22.52.65,port 443 Thursday, Dec 24,2020 03:41:49
[DoS attack: ACK Scan] from source 104.22.53.65,port 80 Thursday, Dec 24,2020 03:41:49
[DoS attack: ACK Scan] from source 104.19.147.8,port 443 Thursday, Dec 24,2020 03:41:42
[DoS attack: ACK Scan] from source 104.16.126.175,port 443 Thursday, Dec 24,2020 03:40:46
[DoS attack: ACK Scan] from source 104.16.19.94,port 443 Thursday, Dec 24,2020 03:40:46
[DoS attack: ACK Scan] from source 104.16.87.20,port 443 Thursday, Dec 24,2020 03:40:45
- schumakuDec 23, 2020Guru - Experienced User
DoS attack? Scratch the idea - these are just effects from the lost connectivity.
