mrob
Feb 11, 2020Guide
Nighthawk Mesh MK62 Dropping Internet Connection
I recently replaced my old router with this setup and the internet connection keeps dropping. Getting a wifi error "No Internet Connection." The wifi signal is strong but the internet connection rand...
abhijeetjoshi
Dec 21, 2020Aspirant
Try resetting to factory or disabling traffic meter. Worked for me. Good luck!
haolecougar
Thanks Abhijeetjoshi.
Provided this connection is "live" long enough for me to do it
Will try this in the morning, risking too much at this point. Was considering another Netgear product when this happened.
Very disappointed.
The nighthawk app is appalling as well. They should fire whoever created. Looks fancy but really doesn't serve its purpose considering how much trouble it had trying to connect even within their own mesh environment.
I hear that Netgear support is bad but hoping for a X'mas miracle!
Peace
- ak3tDec 21, 2020AspirantHopefully you can get yours working soon as it sucks to have those problems! Knock on wood, my mesh system has been working great since I threatened to return it. LOL. 102 def helped and I also had one satellite on a different version than the other two (it would not update) and once It finally updated, everything clicked and started working well. Good luck!
