MarcHChampagne
Nov 21, 2020Guide
Nighthawk mesh MR60 - devices that require 2.4 GHz connection
Please be patient and descriptive in your replies, I pick things up pretty quickly but am far from a network engineer. I upgraded my entire network when the pandemic lockdown started due to my en...
- Nov 27, 2021
Thank you so much worked for me...I turned off my 2 satellites and went into my garage. I connected all my smart outlets in there.
pjcesmat
Dec 18, 2020Initiate
Hi,
I was having this same problem and have literally been scratching my head over it all day. If you go into your Nighthawk Netgear app and create a guest login. I was able to make my devices which require 2.4ghz to work that way. I am guessing guest logins get assigned to 2.4. I hope that helps.
- MarcHChampagneFeb 13, 2021Guide
pjcesmat wrote:Hi,
pjcesmat Thank you for the reply... Sorry it has taken me so long to circle back.
When you say "If you go into your Nighthawk Netgear app and create a guest login" - how, exactly? I don't see an option for this?
My iPhone uses an app that allows me to connect the "smart" plugs in my house (that are now useless). I would have to connect my iPhone to the 2.4 Ghz "guest" login somehow?
Sorry - again I'm an engineer, just not the right kind for this stuff - but learning fast.
- DuarteVicApr 02, 2021Aspirant
I tried using the guest login and it was still 5GHZ!
pjcesmat wrote:Hi,
