MarcHChampagne
Nov 21, 2020Guide
Nighthawk mesh MR60 - devices that require 2.4 GHz connection
Please be patient and descriptive in your replies, I pick things up pretty quickly but am far from a network engineer. I upgraded my entire network when the pandemic lockdown started due to my en...
- Nov 27, 2021
Thank you so much worked for me...I turned off my 2 satellites and went into my garage. I connected all my smart outlets in there.
schumaku
Mar 22, 2021Guru - Experienced User
JamesterReyburg what cost? Find the App on Google Play resp. the Apple App Store, and contact the App maker. Or get in contact wth the maker of your wonderful IoT and point them to this thread resp. my post above.
Again: This is neither a Mesh/router issue nor a problem with the Android or Apple mobile. Granted, both could add controls to allow a 2.4 GHz connection - but for several practical reasons, this isn't available.
JamesterReyburg
Mar 22, 2021Star
My issue isn't with Google (as far as I know). The main problem is with Amazon Echos. They all get on the network, but they pick whatever band they pick, and they can't then cooperate to play music everywhere, because they technically aren't all on the same network. To the best of my understanding. But I had mind-bending issues trying to get myQ garage door to work, an HP printer, and now a wall switch. ALL of these things are the fault of the others and not of Netgear? Apologies, but I don't understand that.
