MarcHChampagne
Nov 21, 2020Guide
Nighthawk mesh MR60 - devices that require 2.4 GHz connection
Please be patient and descriptive in your replies, I pick things up pretty quickly but am far from a network engineer. I upgraded my entire network when the pandemic lockdown started due to my en...
- Nov 28, 2021
Thank you so much worked for me...I turned off my 2 satellites and went into my garage. I connected all my smart outlets in there.
schumaku
Mar 22, 2021Guru - Experienced User
JamesterReyburg what cost? Find the App on Google Play resp. the Apple App Store, and contact the App maker. Or get in contact wth the maker of your wonderful IoT and point them to this thread resp. my post above.
Again: This is neither a Mesh/router issue nor a problem with the Android or Apple mobile. Granted, both could add controls to allow a 2.4 GHz connection - but for several practical reasons, this isn't available.
JamesterReyburg
Mar 22, 2021Star
Okay, you seem to know a lot about this sort of thing, so maybe you can answer this.
I tried *everything* to get my myQ garage door to function to no avail, even got on the phone for an hour with one of the techs at LiftMaster. And it was only when, by chance, I tried enabling the guest network, and hooked to that, and BAM, it worked, first try.
Thinking myself a genius, I tried this with my Amazon Echos. Nope. Tried it with the wall switch. Nope. But the garage door lets me say, "alexa, open sesame," and it still works on the guest network. Why?
Anyway, thanks for your responses. I never heard of "IoT," and I'm the guy most of my friends and family turn to when tech stuff doesn't work. Guess I'm falling behind.
- JamesterReyburgMar 22, 2021Star
I really did find the solution. Youtube tech guy had the easy, easy solution.
https://youtu.be/xarVXR1nSs8
Basically, you just unplug the satellite boxes, walk away with your phone until the network disengages, then walk slowly back until it re-engages. Bada-bing, you're on the 2.4 Ghz connection, and can set up the devices. Worked for the wall switch, worked for the echos. And I'm not dumb enough to even mess with the garage door, it's working on the guest network, it can stay there.Whew.
--Jamie
I should have said: walk away from your HOUSE. . .I had to go about 6 houses away to disengage my connection.
- mrdeuceturboNov 28, 2021Aspirant
- sunspotmomDec 10, 2021Aspirant
Because there is no security with the guest account. I wouldn't think you would want to use guest network to install devices.
- FURRYe38Dec 13, 2021Guru - Experienced User
Is there a security setting for Guest Network on the MK system?
