MarcHChampagne
Nov 21, 2020Guide
Nighthawk mesh MR60 - devices that require 2.4 GHz connection
Please be patient and descriptive in your replies, I pick things up pretty quickly but am far from a network engineer. I upgraded my entire network when the pandemic lockdown started due to my en...
- Nov 27, 2021
Thank you so much worked for me...I turned off my 2 satellites and went into my garage. I connected all my smart outlets in there.
MarcHChampagne
Apr 09, 2021Guide
Seriously? The solution is to disconnect all of my satelites (3) and wrap my router in foil? I paid good money for a router and I have to get out the tin foil?
This router sucks, but I'm beyond the return period...
schumaku
Apr 10, 2021Guru - Experienced User
Seriously: Complain to the maker if this IoJ and whatever smart app used for discovery. At no point it's required the mobile must connect by using the the 2.4 GHz band - for a reason, NO wireless client does allow to force the usage eg. either the 2.4 or the 5 GHz band - why ever, this is what this junk asks for. The single SSID and security key does work on both the 2.4 GHz and the 5 GHz band, a 2.4 GHz only client configured to these settings will connect to 2.4 GHz - except if the wireless clients struggle with the additional bits in place on a Mesh system. In that case again, only the IoJ maker can help.
- JamesterReyburgApr 11, 2021Star
I've seen this sort of reply a few times, that the fault lies with the maker of the app or device. Yeah, well maybe. But it lies with a WHOLE LOT of them. Whirlpool, Liftmaster, Amazon, HP, and a bunch of foreign makers of switches and plugs. I've had problems with almost everything in my lengthy list of "smart" devices since I got the Netgear Nighthawk mesh system. The Ring doorbell and Nest thermostat are the only devices that haven't had an issue.
This is an infuriatingly frustrating problem, and it recurs. Even after everything has been set up, things "fall out" of working, and setup again becomes a torturous process of tinfoil and trying to force the phone to connect to 2.4. Your answer isn't helpful. Contacting a long list of manufacturers, and asking them to change their devices and apps isn't likely to result in a solution.
