MarcHChampagne
Nov 21, 2020Guide
Nighthawk mesh MR60 - devices that require 2.4 GHz connection
Please be patient and descriptive in your replies, I pick things up pretty quickly but am far from a network engineer. I upgraded my entire network when the pandemic lockdown started due to my en...
- Nov 28, 2021
Thank you so much worked for me...I turned off my 2 satellites and went into my garage. I connected all my smart outlets in there.
retromad
Nov 04, 2021Star
Why would I "try" some settings that I am not aware even exist and may not work vs something I know will work? If (random setting you should try) is/was a known good way to add 2.4 devices why is it not the top comment? I get you are trying to be helpful, however, unless you "know" a better way please stop.
Nov 06, 2021Guru - Experienced User
I guess you don't under stand what forums are for then. Forums have user experineces to offer. However it's up to you to try them. If not, then thats your choice. You'll need to contact NG support and ask for there help and information. No need to waste my time.
Good Luck.
