MarcHChampagne
Nov 21, 2020Guide
Nighthawk mesh MR60 - devices that require 2.4 GHz connection
Please be patient and descriptive in your replies, I pick things up pretty quickly but am far from a network engineer. I upgraded my entire network when the pandemic lockdown started due to my en...
- Nov 27, 2021
Thank you so much worked for me...I turned off my 2 satellites and went into my garage. I connected all my smart outlets in there.
JamesterReyburg
Mar 22, 2021Star
I really did find the solution. Youtube tech guy had the easy, easy solution.
https://youtu.be/xarVXR1nSs8
Basically, you just unplug the satellite boxes, walk away with your phone until the network disengages, then walk slowly back until it re-engages. Bada-bing, you're on the 2.4 Ghz connection, and can set up the devices. Worked for the wall switch, worked for the echos. And I'm not dumb enough to even mess with the garage door, it's working on the guest network, it can stay there.
Whew.
--Jamie
mrdeuceturbo
Nov 27, 2021Aspirant
