MarcHChampagne
Nov 21, 2020Guide
Nighthawk mesh MR60 - devices that require 2.4 GHz connection
Please be patient and descriptive in your replies, I pick things up pretty quickly but am far from a network engineer. I upgraded my entire network when the pandemic lockdown started due to my en...
- Nov 28, 2021
Thank you so much worked for me...I turned off my 2 satellites and went into my garage. I connected all my smart outlets in there.
JamesterReyburg
Mar 22, 2021Star
Okay, you seem to know a lot about this sort of thing, so maybe you can answer this.
I tried *everything* to get my myQ garage door to function to no avail, even got on the phone for an hour with one of the techs at LiftMaster. And it was only when, by chance, I tried enabling the guest network, and hooked to that, and BAM, it worked, first try.
Thinking myself a genius, I tried this with my Amazon Echos. Nope. Tried it with the wall switch. Nope. But the garage door lets me say, "alexa, open sesame," and it still works on the guest network. Why?
Anyway, thanks for your responses. I never heard of "IoT," and I'm the guy most of my friends and family turn to when tech stuff doesn't work. Guess I'm falling behind.
sunspotmom
Dec 10, 2021Aspirant
Because there is no security with the guest account. I wouldn't think you would want to use guest network to install devices.
- FURRYe38Dec 13, 2021Guru - Experienced User
Is there a security setting for Guest Network on the MK system?
