MarcHChampagne
Nov 21, 2020Guide
Nighthawk mesh MR60 - devices that require 2.4 GHz connection
Please be patient and descriptive in your replies, I pick things up pretty quickly but am far from a network engineer. I upgraded my entire network when the pandemic lockdown started due to my en...
- Nov 27, 2021
Thank you so much worked for me...I turned off my 2 satellites and went into my garage. I connected all my smart outlets in there.
Whyzer
Jun 24, 2022Aspirant
First off shut off the nighthawk app. Access the router via a webpage, type in 192.168.1.1 and hit enter. Username will be Admin and the password will either be password or 1234, hit enter and you'll connect to the router. It will force you to create a new password and put in some information. Once done you'll be able to see all the router settings.
You can really mess things up if you don't know what you're doing, if you do, reset your router.
At the top you'll see Basic/Advanced settings, go to Advanced. You'll see a category on the left WIFI- select it, by default they have the 2.4Ghz band just off, just enable it by hitting the check box next to it.
Save your settings and you should be able to connect to the items that require 2.4 Ghz network.
sunspotmom
Jun 25, 2022Aspirant
I was using the web browser on a PC.
Thanks, things are working fine. No upgrade for me I'll be getting starlink soon and see if I need anything.
