MarcHChampagne
Nov 21, 2020Guide
Nighthawk mesh MR60 - devices that require 2.4 GHz connection
Please be patient and descriptive in your replies, I pick things up pretty quickly but am far from a network engineer. I upgraded my entire network when the pandemic lockdown started due to my en...
- Nov 27, 2021
Thank you so much worked for me...I turned off my 2 satellites and went into my garage. I connected all my smart outlets in there.
rikeh-santiago
Jul 22, 2022Guide
Our prayer have been heard! I'm guessing with the newest firmware update they added what they call "Customize Wifi Network". In there you can enable separate wifi profiles, one for 2.4GHz and another for 5GHz. Go to Advance > Advance Set Up > Customize Wifi Network. In there click on Customize 2.4Hz, set a network name, password. If you want another one for 5GHz scroll down and you will see the same option but for 5GHz. When you are done click apply and you will have specific Network profiles.
Jul 25, 2022Guru - Experienced User
Enjoy. 📡
