MarcHChampagne
Nov 21, 2020Guide
Nighthawk mesh MR60 - devices that require 2.4 GHz connection
Please be patient and descriptive in your replies, I pick things up pretty quickly but am far from a network engineer. I upgraded my entire network when the pandemic lockdown started due to my en...
- Nov 28, 2021
Thank you so much worked for me...I turned off my 2 satellites and went into my garage. I connected all my smart outlets in there.
JimShane
Nov 06, 2021Guide
on 11-Apr-2021, retromad said "On Android you long press the wifi button on the top pulldown menu then press the connected network (your sid). The network band is listed on the second item labled frequency. It will say either 2.4ghz or 5ghz."
my reply to that, and my advice on this whole issue
i wish my phone would tell that, but my android does not. One of the ways that I can tell is if my ChromeCast icon appears - then I know I am at 2.4. (There are certain rooms in my house that connect at 2.4). Also, if I go outside my stone house, and disconnect and reconnect using that WI-FI icon on my android, I will connect at 2.4. Then I can come into my house and set up any smart plugs (which all use 2.4), or the Chromecast (which also uses 2.4). I must have 50 different devices in my house - all the smartplugs use only 2.4 - I can't remember if the google speakers use 5.1 or not, but I know the Chromecast use 2.4. My LG refrigerator and LG Washer and Dryer all use 2.4. (But, I have found that each time, if I go outside - disconnect and reconnect - then I can do the setup). And once it is set up, then I don't have to worry about the issue again. (Except for Chromecast - which requires that I go out of the rooms that the televisions are in - until the Chromecast Icon appears on my phone (an interior stair case, my bedroom, or outside my house - then I can see the Chromecast icon - cast whatever it is I want to cast, then I can come back in my house and watch the show).
It wasn't me that discovered this - it was my teenagers. I didn't believe them when they first told me. I spent hours trying to figure out why the chromecast button appears once in a while, but not usually. They told me if they go upstairs - then they can do it, then they come back downstairs. I've been doing this for well over a year, and it always works. In fact, I just installed a new chromecast on an attic tv - and the same thing. I go out of the attic - down to my bedroom, then I can see the cast button, and then I can proceed.
Strange, but true.
So regardless of what people tell you that this should happen or not, it does. I have 4 teenagers - I lived through the whole covid thing with all of us on and off the network - and I have learned how to deal with this system - as awkward and strange as that answer is. (I haven't tried the foil. I think I will do that now to see if I have a foil lined box that I can put my phone in and access the tv from the room the tv is in.
Dukestur
Aug 20, 2022Aspirant
Actually the way suggested to determine which network bandwidth you are on does
work. That is on Android devices use the pull down at top of screen and do as directed. And one way to force the change to the other bandwidth is accomplished like you have achieved. I do not know how to force it by some software button push which would be grander. Such a feature would be real nice when using an optimizing mesh network that would continually attempt to move the phone back to 5 GHz.
Your kids solution does explains a lot to me about that Chromecast issue that I like you have.
An alternative solution applicable to the case of adding IOT devices might be to force the network to temporarily only ise the 2.4 GHz band when the manager, you/me, adds IOT devices. Then they can be found and added. The router would be reset to use both bands after that.
Thank you for your help.
