Tnmup18
Jan 07, 2021Tutor
Nighthawk mesh mr60 - satellite same performance as main router unit?
Upgraded to this model - much better than what I had before, even thought that Netgear router wasn't meant to cover the area it did and it did it well until work from home volume increases. Two weeks...
- Jan 07, 2021
it could be that your device is bandsteering from 2.4ghz to 5ghz.
5ghz is much faster.
2.4ghz is much slower and more sensitive to interference.
If its critical to your work, I'd have the office computer hardwired to the primary router. That's going to be your best speeds/performance
Tnmup18
Jan 07, 2021Tutor
Thanks for this answer, and that makes sense, also why I save some money vs. a tri-band system I guess. This morning at 5 am speeds were over 200 download, then at 9am I reran (via Speedtest) and main router was 190.17 / 11.02 upload, office satellite was 125.69 / 10.98 upload. While this may seem ok, I just ran a speed test again from my office at 10:30am and its 49 / 10.34 upload. Is it typical to have such a wide variation from one minute to the next? Just ran it 2 minutes later and now it's 85.77 / 7.01 upload. Earlier around 8am I ran it (yes, I'm fixated) and download was like 20... Ultimately my issue is the 'poor internet connection' on a Zoom call and people advise me my voice is choppy and video freezes... what the heck! Any advice is welcome. I may be relocating the main router to my home office and putting this satellite elsewhere and then possibly running a cable to my work computer. Thanks again for any help and advice.
Jan 07, 2021Guru - Experienced User
- Tnmup18Jan 07, 2021Tutor
Thanks and really appreciate your expertise. I'll assume there's no way to manage the bandsteering? Thanks again. Ken
- plemansJan 07, 2021Guru - Experienced User
its based on a series of factors like bandwidth, rssi, etc.
A couple key things is to make sure to have them spaced properly. they need to be at least 30ft apart to roam properly.
You can also always try to set the 2.4ghz broadcast strength down a bit. some have had luck going that route if the satellites are close and t here's not much interference.
