BOJO3811
Apr 20, 2023Follower
Nighthawk Mesh mr60 bad performance with satellites
With this MR60 router stand-alone my wifi has been fine. No issues. As soon as I add a satellite, performance drops significantly. After working with Netgear’s support and upgrading the firmware, the issues persisted. Finally having a weekend off, I played with the settings myself. Thinking it was an interference issue, I separated the 2.4 and 5 bands with no performance increase. Then I noticed my devices on 2.4 had no issues. Only 5ghz was affected. Then I found the answer.
I disabled 802.11ax (wifi 6). This solved all of my issues and haven’t had problems since. I had issues before even with devices that weren’t wifi 6 capable, so not sure why this works. But it works. I hope this helps the many other people I’ve seen having this issue.
Will look into a different wifi 6 system in the future as this mesh has been more of a pain than what it’s worth.
1 Reply
What Firmware version is currently loaded? Be sure both MR and MS are using same version of FW.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between MR📡 and MS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/000061709/Where-should-I-place-the-Mesh-WiFi-satellite-of-my-Nighthawk-Mesh-WiFi-6-and-Tri-band-Mesh-WiFi-6-products 📡What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try disabling the following and see:
Armor, Smart Parental Controls or Circle, Traffic Meter.Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
