FezAndBow's avatar
FezAndBow
Follower
Sep 18, 2020
Nighthawk Mesh MR60 not at the same speed as the router
Currently, my Nighthawk will be anywhere between 20 mbps download speed and 120 mbps, while the router is at 400. Anyone know what I can do?
1 Reply
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hi FezAndBow,
    If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
    http://www.netgear.com/support/contact.aspx
    Christian
