Avekaj
Nov 11, 2021Follower
Nighthawk Mesh MR60 not broadcasting SSID
Hey all, So I have the Nighthawk Mesh system in my home. I have the Nighthawk MR60 (router) and Nighthawk MS60 (satellite). My network is set up like this: Modem -> Nighthawk MR60 (Router) Wi...
Nov 12, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Most of the people who watch that forum are more likely to have experience with NH router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6
Try powering OFF the ISP modem and MR and MS for 1 minute or more and then back ON.
Try changing channels on the MR, try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Thank you.
