bpietranton
Aug 26, 2020Follower
Nighthawk Mesh MR60 Satellite connection issues
Hello All, I have receently purcheed the Nighthawk Mesh WiFi 6 System. I hooked everything up a couple days ago without any issues. The system worked perfectly and I saw drastic improvement. Just...
Christian_R
Sep 01, 2020NETGEAR Employee Retired
Hi bpietranton,
Welcome to the community! If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
http://www.netgear.com/support/contact.aspx
Christian
