bpietranton
Aug 26, 2020Follower
Nighthawk Mesh MR60 Satellite connection issues
Hello All, I have receently purcheed the Nighthawk Mesh WiFi 6 System. I hooked everything up a couple days ago without any issues. The system worked perfectly and I saw drastic improvement. Just...
wtfareprntlcntr
Feb 09, 2021Guide
Check to see if your router and satellites are on the same firmware version. Mine is having the same issue but they are on different firmware versions and the satellites are not updating.
