bpietranton
Aug 26, 2020Follower
Nighthawk Mesh MR60 Satellite connection issues
Hello All, I have receently purcheed the Nighthawk Mesh WiFi 6 System. I hooked everything up a couple days ago without any issues. The system worked perfectly and I saw drastic improvement. Just...
stephen_p
Mar 01, 2021Initiate
Works well, when it works. Mine was good for about 4 months, then satellites stopped connecting. Wasted a lot of time. Netgear support is a disgrace. After your free 90 days of support you are basically on your own unless you want to pay them more money. Otherwise you will have to rely on these forums. From what I could find even the people who had support tickets were getting very slow responses and were usually told to turn off the wifi 6 features to make it work or make all kinds of tweaks you shouldn't have to do to make a product work.
Bottom line is this product is not reliable and Netgear will not help you fix it. I had to turn off the satellites so now have much slower speed in my office. Total waste of money, would never buy Netgear again.
Hope you can find a fix!
