bpietranton
Aug 26, 2020Follower
Nighthawk Mesh MR60 Satellite connection issues
Hello All, I have receently purcheed the Nighthawk Mesh WiFi 6 System. I hooked everything up a couple days ago without any issues. The system worked perfectly and I saw drastic improvement. Just...
Wldbear
Aug 25, 2021Initiate
I recently ran into the same problem. The update failed on one Satellite, and then it would only blink white. Resets didn't help, and it wouldn't connect to the main router so I couldn't update it. The fix was in the artcle https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client. The only difference was I had to push out the file, then unplug and replug in while holding the reset button. Once the light turned amber I let go. After about a minute or so the white light stopped flashing and went to amber, then to blue. All connected again.
