lsmitharena's avatar
lsmitharena
Follower
Jul 09, 2021
Nighthawk Mesh MR60
We lost power. Before the power outage, my Netgear was Netgear 69.  I was able to reset the Nighthawk but now it says Netgear Set up.  My Wifi is working but I'm not sure I hae the level of security I'm supposed to have and a few things cannot connect.  I don't know how to reset it to Netgear 69
1 Reply
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hello lsmitharena,
    May you factory reset your MR60 by holding down on the reset button located at the back/bottom of the router. You will need to press down on the reset button for 15+ seconds using a pin/needle. After resetting the unit, please use the Nighthawk app to setup your router again.
    Christian
