bvswan614
Sep 07, 2020Tutor
Nighthawk Mesh Problem
Nighthawk Mesh WiFi 6 system MK63, AX1800. Not sure whey this doesn't appear in the pulldown window. Installed this system about a month ago. It work flawlessly up until a few days ago. We had n...
DuckAmuck
Dec 14, 2020Aspirant
Similar problems. Satellites occasionally lose sync randomly, then re-sync automatically after some minutes No changes to network.
DuckAmuck
Dec 16, 2020Aspirant
Since satellites keep losing sync, trying an experiment of using only one satellite. I've not reset the configuration, so the Nighthawk app still thinks there are two satellites. So far, so good. I'll update tomorrow.
- DuckAmuckDec 17, 2020Aspirant
Experiment failure. Single satellite lost sync this morning. Only saving grace is that router does not lose network and has decent coverage.
