bvswan614
Sep 07, 2020Tutor
Nighthawk Mesh Problem
Nighthawk Mesh WiFi 6 system MK63, AX1800. Not sure whey this doesn't appear in the pulldown window. Installed this system about a month ago. It work flawlessly up until a few days ago. We had n...
ADadsLife
Oct 02, 2021Aspirant
Has anyone solved this Issue? I'd like to keep using it as I've had it longer than a year now, but it's gotten to the point where the satellite drop outs are really affecting the quality of our work and productivity at home. Going from an 80-90mbps connection to 3mbps can really drive a guy nuts.... ANY ideas would be much appreciated.
Oct 03, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between MR and MS to begin with depending upon building materials when wirelessly connected.
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
