Dustin_V
May 20, 2020NETGEAR Employee Retired
Nighthawk Mesh Q&A with Product Manager, Arun K. - May 27 to June 2
Update: The Nighthawk Mesh Q&A has been extended through Tuesday, June 2! Here is your chance to ask your Nighthawk Mesh WiFi 6 System questions to Arun, so don't miss out!
Join us on We...
akong
May 29, 2020Guide
Question 1 : This is related to this community thread (Q&A with Product Manager), why is the model not listed in the popup list to pick for the Nighthawk Mesh Wifi6 System (MR60, MS60)? Isn't this the system we are wanting to discuss on this thread?
Question 2: If AX is backward compatible, we do we still need to enable or disable AX feature on the router?
Question 3: Where is there an option to disable beam forming if it is support to be good in extending range?
Question 4: Are you aware of the intermitten disconnectivity issues reported by the communicty that is inherent in the MK6x system?
arunkmony
May 29, 2020NETGEAR Employee Retired
akong wrote:Question 1 : This is related to this community thread (Q&A with Product Manager), why is the model not listed in the popup list to pick for the Nighthawk Mesh Wifi6 System (MR60, MS60)? Isn't this the system we are wanting to discuss on this thread?
Dustin_V , kindly check this issue.
akong wrote:Question 2: If AX is backward compatible, we do we still need to enable or disable AX feature on the router?
No, WiFi 6 or AX will automatically detect previous generation 11ac devices and connect and function normally. The checkbox can be left in its default ON position. Turning off is for debug purposes.
akong wrote:Question 3: Where is there an option to disable beam forming if it is support to be good in extending range?
akong , please refer to the User Manual for configuration options. It's listed on the UM page 74.
akong wrote:Question 4: Are you aware of the intermitten disconnectivity issues reported by the communicty that is inherent in the MK6x system?
Yes, we are actively looking into all issues faced by customers related to the Nighthawk Mesh system. As always we are trying to improve firmware so our customers can get the best experience with the product.
If anyone is facing an issue, please reach out to NETGEAR support team so that we can get it working for you. We are looking for volunteers who can work with our tech support and engineering team to debug disconnect issues faced by them.
