Dustin_V
May 20, 2020NETGEAR Employee Retired
Nighthawk Mesh Q&A with Product Manager, Arun K. - May 27 to June 2
Update: The Nighthawk Mesh Q&A has been extended through Tuesday, June 2! Here is your chance to ask your Nighthawk Mesh WiFi 6 System questions to Arun, so don't miss out!
Join us on We...
arunkmony
Jun 02, 2020NETGEAR Employee Retired
mjcalabrese wrote:
MK62-100NAS - Netgear Nighthawk Wifi 6 Mesh AX1800
Hardware Version MR60 / MS60
Firmware Version MR60-V1.0.4.92_2.0.38 / MS60-V1.0.4.92_2.0.38
Recently purchased this system and it is working fairly well, but I have run into some issues that tech support has yet to answer for me. Maybe you can help me.
- The MS60 unit is currently connected via 5GHz backhaul. This causes some bandwidth reductions 40-60% on the MS60 end. I tested with a CAT5e cable and the MS60s speeds nearly matched the MR60 devices. Is this to be expected if Ethernet backhaul is not used?
The backhaul for MR60 is shared so as you add more devices to the network, you may see the speeds reducing a bit. Ethernet does not suffer from this, so when ethernet backhaul is used, the speed reduction will not occur.
- The MS60 does not sync to the MR60 when it comes to the 2.4 GHz channels. Currently the MR60 is assigned to Channel 11, but the MS60 is using Channel 8. I see no way to set the channels on the MS60 end - Can this be added in the future? [Or at least only choose from channels 1 - 6 - 11 on the 2.4 GHz end so there is no overlap/interference]. on 5GHz, the channels are sync'd to Channel 153, but this is probably because the 5G backhaul is in use.
There is an option to fix the 2.4G channel. Please check the user manual for configuring it. If you are interested in being part of users to try new test firmware please PM me and I'll connect with the team. https://www.netgear.com/support/product/mk62.aspx#docs
- On occasion, I will lose connectivity on 5GHz devices connected to the MS60. Not sure what the reason is, but I have tried to reset the network connections on these devices (laptop, Smart TV, and iPhone XR) and do not see any IP Address being issued, but I do see the successful DHCP request in the MR60 logs. I was about to reboot everything last evening so I walked upstairs to the MR60 and my iPhone connected ... [hmm, must be the MS60, so I rebooted it and everything was working again --- could it be the MS60 is defective?]
Thanks for any help you can give me on these topics/questions.
It's unlikely to have a defective satellite. In case you see the problem again, please raise a support ticket so we can help with debugging the issue.
akong
Jun 03, 2020Guide
arunkmony wrote:The backhaul for MR60 is shared so as you add more devices to the network, you may see the speeds reducing a bit. Ethernet does not suffer from this, so when ethernet backhaul is used, the speed reduction will not occur.
Just for my own sanity check...Are you saying the backhaul connection is competing in the same channel as the rest of the end devices over the 5GHz band? If so, why not allows us to configure a different channel in the 5GHz band for the backhaul?
- schumakuJun 03, 2020Guru - Experienced User
Yes, this is what arunkmony explained.
akong wrote:If so, why not allows us to configure a different channel in the 5GHz band for the backhaul?
Because there are only two 802.1ax radios on each these Nighthawk Mesh devices - one 2.4 GHz, one 5 GHz.
- mjcalabreseJun 04, 2020Apprentice
I have tested this three different ways on the MS60 end. Here are my results.
baseline Spectrum-Charter broadband service (200MB down - 10MB up) actual results from the router (230MB down - 11MB up):
testing results (using Ookla Speedtest app on my iOS/iPhone XR device) - Zbook 15G3 laptop for wired test:
MR60 end:
WiFI 228MB / 11MB ; Wired 230MB / 11MB up
MS60 end:
Ethernet backhaul [using (PL2200) Powerline adapters]: WiFi (only): 65-90MB down / 10MB up
5GHz backhaul: WiFi 120-160MB / 11MB up
Ethernet [CAT5e cabling installed]: WiFi: 180-228MB down / 11MB up
I decided to remove the Powerline adapters wherever possible and pull cable. This resolved two issues: (1) fluctuation in performance speeds of the PL adapters in my home with AFCI breakers in my breaker panel and (2) losing connectivity should the power go out in my home (my network equipment is on battery backup.)
Hope this helps anyone else with questions on Ethernet backhaul.
- schumakuJun 04, 2020Guru - Experienced User
mjcalabrese excellent comparison, hope that is useful for others.
Aside, I don't think that usual AFCI breakers should have an impact. Are you living in your own house, or can there be other PLC communication near, e.g. from neighbours, PLC based Internet service over power lines? Note that there are two PLC standards which have a massive performance impact if used on the same circuits (even ways beyond of your breaker panel).
Love the message overall: There is no better communication possible than by using network cables (or fiber)! anything else is full of compromises and potential problems.
