SteveBen
Oct 08, 2021Guide
Nighthawk Mesh Router Can't Connect to Netflix, AppleTV or Prime
Netgear Nighthawk Whole Home Mesh WiFi 6 System, 3-Pack (MK63-100NAS) I unfortunately this brand new (2021) wifi 6 Nighthawk router. I bought it because I have a four-story house with a TV and a ...
- Oct 18, 2021
SOLVED!! I went to Best Buy and got an eero 6 mesh router. Easiest setup ever. It took 15 minutes using the phone app. Every TV, computer, phone and BT speaker accessed the network immediately, and we've had zero problems!
SteveBen
Oct 09, 2021Guide
Over the 6 or so hours I worked with Netgear technicians (and the hour with the CenturyLink tech) I don't believe that was one of the things we tried. I would have no idea how to do what you suggest. Why do you think the Netgear tech didn't try that? Thanks.
Oct 10, 2021Guru - Experienced User
SteveBen wrote:
Why do you think the Netgear tech didn't try that? Thanks. -I've got no idea why the techs do what they do or why ISP's force users to have one of their gateways. But its worth a shot.
- SteveBenOct 10, 2021Guide
Thanks. I finally got Netgear to agree to refund my purchase. I'm moving on and will never buy another Netgear product. Appreciate your willingness to help though. Cheers.
