SteveBen
Oct 08, 2021Guide
Nighthawk Mesh Router Can't Connect to Netflix, AppleTV or Prime
Netgear Nighthawk Whole Home Mesh WiFi 6 System, 3-Pack (MK63-100NAS) I unfortunately this brand new (2021) wifi 6 Nighthawk router. I bought it because I have a four-story house with a TV and a ...
- Oct 18, 2021
SOLVED!! I went to Best Buy and got an eero 6 mesh router. Easiest setup ever. It took 15 minutes using the phone app. Every TV, computer, phone and BT speaker accessed the network immediately, and we've had zero problems!
SteveBen
Oct 10, 2021Guide
Thanks. I finally got Netgear to agree to refund my purchase. I'm moving on and will never buy another Netgear product. Appreciate your willingness to help though. Cheers.
Oct 10, 2021Guru - Experienced User
good luck on your next device!
I've had good luck with tplink and asus devices.
- SteveBenOct 11, 2021Guide
Everything I've been reading is recommending Google wifi 6, mesh routers. Either the AC1200 or the Nest. What do you thing?
- plemansOct 11, 2021Guru - Experienced User
I tend to push triband versus dual band. when you're using a single/dual band device and using mesh, the satellites take a significan throughput hit.
so if you're going to go with mesh, I'd look for a triband device.
Thanks for the advice. You've been great! I'm on a bit of budget, ($250 that I would hate to push to $300) so any reccomendations on a specific TP-Link or Asus? I have a four story home, so do I still need satellites on the two furthest away floors? If you had my budget, what would you buy?
Thanks!
Steve
