Spydrjon
Feb 08, 2020Follower
Nighthawk mesh slow speed
I have installed a new nighthawk WiFi 6 mesh router with 1 satellite. I am getting great speed on speed test from the fiber, but the WiFi speeds SUCK. when I look at the network map, everything seems ...
Christian_R
Mar 12, 2020NETGEAR Employee Retired
Hello BrrZrrKr,
May you let us know the current firmware version the Nighthawk mesh is on.
Thanks,
Christian
BrrZrrKr
Mar 12, 2020Aspirant
It is currently
| Firmware Version | V1.0.2.76_2.0.28 |
- araghavaMay 14, 2020Star
I'm on firmware version V1.0.4.92_2.0.38 and the system is working much better.
- SKR2710Jun 18, 2020Aspirant
I have the same problem after spending hours and hours with Netgear customer service they told me to return the device.
My Modem gets 500Mbps + speed and with hard wired to router its only 200Mbps, its 500Mps on Iphone when am in front of the router once go farther the speed on iPhone varies from 50-100mbps. I couldn't understand what is the use of the satellite then if wifi speed is downgraded significantly when you are away from the router and closure to the satellite. My firmware is up to date.
araghava wrote:I'm on firmware version V1.0.4.92_2.0.38 and the system is working much better.
- SKR2710Jun 19, 2020Aspirant
Has this issue been resolved for anyone? What was the resolution?
