Spydrjon
Feb 08, 2020Follower
Nighthawk mesh slow speed
I have installed a new nighthawk WiFi 6 mesh router with 1 satellite. I am getting great speed on speed test from the fiber, but the WiFi speeds SUCK. when I look at the network map, everything seems ...
kest86
Sep 01, 2020Aspirant
This is not true information. The numbers on sattelite #1 will read 174mbs via Ethernet, but sattelite #2 will only read 62mbs when placed in the same exact space and using the same exact cables.
This shows that the two sattelites are not working the same. One is faster and one is slower. Therefore, I feel that sattelite #2 is defected.
Please advise. Thank you.
edrios
Sep 01, 2020Star
Also, if the test laptop is in fact connected to the last sattelite unit in line, assuming they are serialy meshed, and I can get 200 from the wireless, doesn't it ound irrational to believe that your Ethernet connection would be even less than that. Since when did wireless connections become faster than hard wired connections, comming out of the same unit. That looks like a cap on the Ehternet port. I don't know if you work for Netgear, but there is really something off with these units.
- kest86Sep 01, 2020Aspirant
I do not work for Netgear. I agree with you 100% - it makes no sense that my wireless numbers are faster than my Ethernet numbers, but that is the case. I cannot figure this out. These things are defected and not working the way they should.
I think you might be getting confused. When I replied to your post, I was just saying that I was also having issues / problems and explained what is happening to me. I am tried the sattelites in the same spot in my home - I was not referring to your home. Hope this clears things up a bit.
- edriosSep 05, 2020Star
Got you! Got scared for a minute there when you told me about the positions of the satellites, as if you could relatively tell how far they were from each other in my own network. Thought you were an employee with insight into the equipment. In any case, the real culprit seems to be a bad jumper from the satellite to the 1 gig switch. I was using the ports on that swtich in the office to test as well. I didn't even check the cable because the failure looked like it was intermittent, and it seemed to be happening 1 hour after all 3 units were activated. But it was happening by me switching the computer from a direct plut into the satellite and switching it over to the switch. A fricking bad new jumper out of the package that I bought from Amazon. I bought 15 new cat6 jumpers to repurpose whole network for Wi-Fi 6 and the last thing I would have suspected was a bad cable. All ethernet ports are now at 1 1Gig. Thanks for you insights!
