Browndogcleo's avatar
Browndogcleo
Follower
Feb 28, 2025
Nighthawk Mesh wifi 6 Apple compatibility - continually dropping network
I have never had a problem with my Nighthawk router until yesterday. None of my apple products will retain the connection with the router - continually dropping in and out.
Connection with all other products including laptops, tvs, digital boxes etc is fine.
I have reset everything - nbn box, router, devices. updated ios on iPhone. Nothing has helped.
I'm not a techy and am getting very frustrated.
Please help?
1 Reply
  • FURRYe38's avatar
    Which iphone models do you have?
    What iOS version is loaded on the phones?
    Which NH MESH model system do you have MK##?
    Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
    How many MS are deployed?
    What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
    What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    https://kb.netgear.com/23783/How-do-I-change-the-wireless-channel-on-my-NETGEAR-router
    Be sure to disable any MAC Address randomizers on phones and pads while at home:
    https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message
    Armor, IPv6, Smart Parental Controls or Circle, Traffic Meter.
