Yesimkidding
Mar 10, 2021Aspirant
Nighthawk Mesh WiFi 6, how to disable 5ghz
I am trying to connect a Traeger Silverton 810 smoker, and it requires 2.4ghz. During the pairing process, it must temporarily connect to my phone... which is connecting to my router via 5ghz. How ...
cbell4444
Mar 18, 2021Star
schumaku wrote:At no point, it's required that the phone is connected to the 2.4 GHz radio on your Nighthawk Mesh network - the data is the same for the 2.4 and the 5 GHz.
Complain with the crApp maker to remove the nonsense test that the phone "must" be connected to a "2.4 GHz network", at least they should add a "continue" button at this step.
Hey schumaku , lighten up already, ok? The OP just wants some help. This stuff your posting in several 'disable 5GHz' forums isn't helpful. Worse, it's plain wrong. I know it's 2021 and it shouldn't be required. And yes, the device vendor could write better software. Nevertheless, based on the hundreds of posts about this problem across several product lines, the primary responsibility for fixing this belongs to NG. It's their job to be compatible with multiple vendors.
Happy to discuss this more here. No need to muck up the OP's thread with posts that won't help him.
Yesimkidding
Mar 18, 2021Aspirant
Thank you both for your input. I think that both Netgear, and Traeger should resolve this technical issue. None of my other devices were this impossible to connect to my dual band router, so I think Traeger needs to revise the manner in which the pairing happens.
- retromadMar 22, 2021Star
See the post here
you can use foil to kill your 5ghz network mode. It aint pretty - but it does work...
- AmyMilesMay 21, 2021Aspirant
Sometime it happens when you try to connect the smoker with wifi or any other internet device. The latest and updatted versions have already sorted out this issue for better user experience. I wish you find a better solution.
- JimShaneNov 06, 2021GuideThis happens to me all the time, and it's frustrating. It happens when I want to install a new smart switch (all if them are at 2.4). It happens with our chromecast devices.
My teenagers discovered that often there is no cast icon when in the room where a TV is. But, if the leave the room and cast fro. Another room, the icon appears (then they can come back into the roo. The tv is in)
I have tried this dozens of times over the last year, and it works.
When I want to install a new smart switch, I ho outside our stove house. Then I hit the wifi button on my android phone to disconnect, then I press it again to reconnect. Even though I can't tell what speed it connects at, it seems that it must connect at 2.4 outside our house, in the interior stairwells, and in my bedroom.
I agree it shouldn't work this way, but it does. Just today I installed a chromecast in our attic tv, and it works just this way.
